水和水蒸汽性质表软件 winsteam在excel中使用
压力单位为bar
stmpth(压力,温度,1) ------根据压力、温度求焓
stmpht(压力,焓,1) ------根据压力、焓求温度
StmPQH(压力,1,1) ------根据压力求饱和蒸汽焓
StmPQH(压力,0,1) ------根据压力求饱和水焓
StmTQH(温度,1,1) ------根据温度求饱和蒸汽焓
StmTQH(压力,0,1) ------根据温度求饱和水焓
StmPT(压力,1) ------根据压力求饱和温度
stmTP(温度,1) ------根据温度求饱和压力
Quality:1为汽,0为水
Function Input(s) Output
StmPT() Pressure Saturation Temperature饱和温度
StmTP() Temperature Saturation Pressure饱和压力
StmTQH() Temperature, Quality Enthalpy
StmTQS() Temperature, Quality Entropy
StmTQV() Temperature, Quality Specific Volume比容
StmTQC() Temperature, Quality Specific Heat
StmTQK() Temperature, Quality Thermal Conductivity导热系数
StmTQM() Temperature, Quality Dynamic Viscosity
StmTQW() Temperature, Quality Sonic Velocity
StmTQG() Temperature, Quality Isentropic Expansion Coefficient
StmPQH() Pressure, Quality Enthalpy
StmPQS() Pressure, Quality Entropy
StmPQV() Pressure, Quality Specific Volume
StmPQC() Pressure, Quality Specific Heat
StmPQK() Pressure, Quality Thermal Conductivity
StmPQM() Pressure, Quality Dynamic Viscosity
StmPQW() Pressure, Quality Sonic Velocity
StmPQG() Pressure, Quality Isentropic Expansion Coefficient
StmPTH() Pressure, Temperature Enthalpy 焓
StmPTS() Pressure, Temperature Entropy 熵
StmPTV() Pressure, Temperature Specific Volume 比容
StmPTC() Pressure, Temperature Specific Heat 比热
StmPTK() Pressure, Temperature Thermal Conductivity 导热系数
StmPTM() Pressure, Temperature Dynamic Viscosity 动力粘度
StmPTW() Pressure, Temperature Sonic Velocity 声速
StmPTG() Pressure, Temperature Isentropic Expansion Coefficient 等熵膨胀系数
StmPHT() Pressure, Enthalpy Temperature
StmPHS() Pressure, Enthalpy Entropy
StmPHV() Pressure, Enthalpy Specific Volume
StmPHQ() Pressure, Enthalpy Quality
StmPHC() Pressure, Enthalpy Specific Heat
StmPHW() Pressure, Enthalpy Sonic Velocity
StmPHG() Pressure, Enthalpy Isentropic Expansion Coefficient
StmPST() Pressure, Entropy Temperature
StmPSH() Pressure, Entropy Enthalpy
StmPSV() Pressure, Entropy Specific Volume
StmPSQ() Pressure, Entropy Quality
StmPSC() Pressure, Entropy Specific Heat
StmPSW() Pressure, Entropy Sonic Velocity
StmPSG() Pressure, Entropy Isentropic Expansion Coefficient
StmTEMPIT() Temperature, 1968 scale Temperature, 1990 scale
StmTEMPTI() Temperature, 1990 scale Temperature, 1968 scale
StmVER() None Version/serial no. |
